[gdal-dev] MrSID won't compile with GDAL 1.9 - libgeotiff issue
Even Rouault even.rouault at mines-paris.org
Tue Apr 3 17:31:05 EDT 2012
Le mardi 03 avril 2012 23:07:51, Gavin Fleming a écrit :
> Hi
> I've just upgraded to gdal 1.9 on Ubuntu 11.10. When I tried to compile
> MrSID support (which was working fine in 1.8) I get this:
> checking for XTIFFClientOpen in -lgeotiff... no
> configure: error: libgeotiff is required to build GDAL MrSID driver
> with both these MrSID versions:
> gdal-mrsid-build
> /usr/local/MrSID_DSDK-8.5.0.3422-linux.x86-64.gcc44/Raster_DSDK/
> (for this I also had to disable jp2mrsid in the gdal-mrsid-build script)
> and
> gdal-mrsid-build /usr/local/Geo_DSDK-7.0.0.2167/
> I have libgeotiff 1.3 and 1.2.5 installed.
> Anyone had the same experience?
Hum, this should be something to report to the ubuntugis team. This build
script isn't maintained by the GDAL project itself.
Looking at the symbols needed by libltidsdk.so from the 8.0.0 SDK, there's no
reason from requiring libgeotiff to build the MrSID SDK.
I'm wondering if this error doesn't come from the fact that GDAL 1.9.0 in
ubuntugis is now built with versionned symbols now.
