[gdal-dev] Slow writing into Spatialite with -skipfailures
Even Rouault
even.rouault at mines-paris.org
Wed Apr 4 15:11:39 EDT 2012
Le mercredi 04 avril 2012 21:01:29, Martin Chapman a écrit :
> Try to execute this query before you start inserting:
> "PRAGMA synchronous = 0;"
> It turns synchronous writes off for sqlite and give a big performance
> increase. I don't know if that will work for spatialite but it might.
> You need to read about the ramifications on the sqlite web site first
> though so you understand the trade-offs. Also, it may have no effect when
> using it via gdal. I can't answer that one.
Good suggestion. Actually this can be used with GDAL by setting the
OGR_SQLITE_SYNCHRONOUS configuration option to OFF. See
http://gdal.org/ogr/drv_sqlite.html
> Martin
> -----Original Message-----
> From: gdal-dev-bounces at lists.osgeo.org
> [mailto:gdal-dev-bounces at lists.osgeo.org] On Behalf Of Jukka Rahkonen
> Sent: Wednesday, April 04, 2012 10:37 AM
> To: gdal-dev at lists.osgeo.org
> Subject: [gdal-dev] Slow writing into Spatialite with -skipfailures
> Hi,
> I had to write a million polygon shapefile into Spatialite with
> -skipfailures and I noticed that it was very many times slower that
> without -skipfailures. Is there some logical reason for that or could it
> be due to a bug or something?
> Only thing that comes into my mind is that if the -gt parameter is taken
> into account or not.
> -Jukka Rahkonen-
> gdal-dev mailing list
