[gdal-dev] bring through shapefile attribute in gdal_rasterize
Derek Morgan
jdmorgan at unca.edu
Sun Apr 8 21:26:11 EDT 2012
Hello GDAL colleagues,
This may be a simple question for most of you but I thought I would
ask it anyhow as I am at an impasse. I have a Counties shape file. I
am attempting to convert it to raster utilizing gdal_rasterize, and
this does work. However, I am attempting to carry into the output
file the county name preferably e.g. Orange County, or at least a
county identify of some kind. I have utilized a command similar to
the following:
gdal_rasterize -a COUNTY -l -sql "select COUNTY, * from Counties"
Counties Counties.shp CountiesRaster.tif
However, when I open the resulting raster file in ArcGIS and click on
one of the pixel to identify it I don’t see the county name. Is the
county name there and I am just not seeing it in ArcGIS indentify. I
realize there are probably more GDAL intensive ways to check for the
data, but I am still learning. I was hoping to someone could explain
to me what I am doing incorrectly.
Thanks,
Derek
