[gdal-dev] bring through shapefile attribute in gdal_rasterize
Eli Adam
eadam at co.lincoln.or.us
Mon Apr 9 10:49:54 EDT 2012
Derek,
> This may be a simple question for most of you but I thought I would
> ask it anyhow as I am at an impasse. I have a Counties shape file. I
> am attempting to convert it to raster utilizing gdal_rasterize, and
> this does work. However, I am attempting to carry into the output
> file the county name preferably e.g. Orange County, or at least a
> county identify of some kind. I have utilized a command similar to
> the following:
> gdal_rasterize -a COUNTY -l -sql "select COUNTY, * from Counties"
> Counties Counties.shp CountiesRaster.tif
I think that -l should specify the layer name from the source dataset
not the field. Typically in a shapefile there is only one layer and
it is the same as the shapefile name. Try dropping the -l stuff all
together.
gdal_rasterize -a COUNTY Counties.shp CountiesRaster.tif
or if you use it, use it like this:
gdal_rasterize -a COUNTY -l Counties Counties.shp CountiesRaster.tif
> However, when I open the resulting raster file in ArcGIS and click on
> one of the pixel to identify it I don’t see the county name. Is the
> county name there and I am just not seeing it in ArcGIS indentify. I
> realize there are probably more GDAL intensive ways to check for the
> data, but I am still learning. I was hoping to someone could explain
> to me what I am doing incorrectly.
You can get information from a raster in GDAL with gdallocationinfo.
HTH, Eli
> Thanks,
> Derek
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
