[gdal-dev] OpenJpegDataset IReadBlock question
Joaquim Luis
jluis at ualg.pt
Tue Apr 10 12:08:42 EDT 2012
On 10-04-2012 13:14, Robert Zermeno wrote:
> Ladies and Gents,
> I have yet to properly configure GDAL to compile with a repository
> OpenJpeg V2, but I wanted to see how GDAL uses openjpeg tile request.
> I created my own project and modified IReadBlock() to be standalone to
> view a tile request.
This is probably not of much help because I did nothing special to build
GDAL with OpenJpeg V2 on Windows using VS2010. I compiled OpenJpeg with
the help of the CMake scripts and than linked as explained on nmake.opt.
I did not do any particular testing, but for example running with this
test file looks fine
C:\programs\GDALtrunk\gdalautotest-1.8.0\gdrivers\data>gdalinfo byte.jp2
Driver: JP2OpenJPEG/JPEG-2000 driver based on OpenJPEG library
Files: byte.jp2
Size is 100, 100
Coordinate System is:
PROJCS["NAD27 / UTM zone 11N",
Joaquim
> I am using a sample data file provided by openjpeg data folder named
> p1_04.j2k. How is the data retrieved from opj_decode_tile_data() is
> being stored in the buffer? To access pixel 0, is it just buffer[0]
> or is there another way?
> For some reason, my request for Tile (0,0) of length 128x128 returns
> an image that looks masked. The image is mostly black and white with
> no depth of shading (i.e. missing information).
> This image also uses 12 bits-per-pixel which I do not see where GDAL
> truncates the image data down to 8 bits-per-pixel. Does GDAL return
> the raw 12 bits-per-pixel forcing the user to truncate the data
> properly for every pixel or is it handled by GDAL (If so, where)?
> I hope to figure out why GDAL does not link properly to openjpeg V2
> for others use this option again. I hope someone can provide me the
> answers to the questions I have asked.
> Thanks,
> John
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20120410/67c7d8a0/attachment.html
