[gdal-dev] Problem with GDAL data folder in 1.9
Frank Warmerdam
warmerdam at pobox.com
Tue Apr 10 16:05:50 EDT 2012
Ivan,
I don't see any *errors* in the new results. The order of the
standard parallels is arbitrary. But it is odd how different the
PCS name is and that the EPSG authority code is not preserved.
I will note that gdalsrsinfo against 1.9 for EPSG:26943 reports:
... Ah Etienne already beat me to this.
In any event, I think you would need to file a ticket and provide a
sample file demonstrating the issue for us to track through. It
could be something specific about the geotiff driver.
Best regards,
On Tue, Apr 10, 2012 at 12:50 PM, Ivan Lucena <ivan.lucena at pmldnet.com> wrote:
> Hi There,
> I am getting some weird results from a simple geotiff file and it seems to be a problem with the data folder.
> If I run gdalinfo using GDAL 1.9 or 1.8 with the data folder installed from 1.8 the WKT comes with no EPSG Authority code:
> D:\> set GDAL_DATA=D:\GDAL-1.9\data
> D:\> gdalinfo sf1.gtif
> PROJCS["NAD_1983_StatePlane_California_III_FIPS_0403",
> GEOGCS["GCS_North_American_1983",
> DATUM["North_American_Datum_1983",
> SPHEROID["GRS_1980",6378137,298.257222101]],
> PRIMEM["Greenwich",0],
> UNIT["Degree",0.0174532925199432955]],
> PROJECTION["Lambert_Conformal_Conic_2SP"],
> PARAMETER["False_Easting",2000000],
> PARAMETER["False_Northing",500000],
> PARAMETER["Central_Meridian",-120.5],
> PARAMETER["Standard_Parallel_1",37.06666666666667],
> PARAMETER["Standard_Parallel_2",38.43333333333333],
> PARAMETER["Latitude_Of_Origin",36.5],
> UNIT["Meter",1]]
> Even tough listgeo shows:
> PCS = 26943 (NAD83 / California zone 3)
> Projection = 10433 (SPCS83 California zone 3 (meters))
> Projection Method: CT_LambertConfConic_2SP
> ProjFalseOriginLatGeoKey: 36.500000 ( 36d30' 0.00"N)
> ProjFalseOriginLongGeoKey: -120.500000 (120d30' 0.00"W)
> ProjStdParallel1GeoKey: 38.433333 ( 38d26' 0.00"N)
> ProjStdParallel2GeoKey: 37.066667 ( 37d 4' 0.00"N)
> ProjFalseEastingGeoKey: 2000000.000000 m
> ProjFalseNorthingGeoKey: 500000.000000 m
> GCS: 4269/NAD83
> Datum: 6269/North American Datum 1983
> Ellipsoid: 7019/GRS 1980 (6378137.00,6356752.31)
> Prime Meridian: 8901/Greenwich (0.000000/ 0d 0' 0.00"E)
> Projection Linear Units: 9001/metre (1.000000m)
> But if I use gdalinfo 1.8 or 1.9 with the data folder from 1.8 the WKT appears to be better.
> D:\> set GDAL_DATA=D:\GDAL-1.8\data
> PROJCS["NAD83 / California zone 3",
> GEOGCS["NAD83",
> SPHEROID["GRS 1980",6378137,298.2572221010002,
> AUTHORITY["EPSG","7019"]],
> AUTHORITY["EPSG","6269"]],
> UNIT["degree",0.0174532925199433],
> AUTHORITY["EPSG","4269"]],
> PARAMETER["standard_parallel_1",38.43333333333333],
> PARAMETER["standard_parallel_2",37.06666666666667],
> PARAMETER["latitude_of_origin",36.5],
> PARAMETER["central_meridian",-120.5],
> PARAMETER["false_easting",2000000],
> PARAMETER["false_northing",500000],
> UNIT["metre",1,
> AUTHORITY["EPSG","9001"]],
> AUTHORITY["EPSG","26943"]]
> The authority code are correct and standard_parallel_1, standard_parallel_2 are identical to listgeo information.
> I got this files from the SVN branch 1.8 and 1.9 and I compiled and install it myself but I also tried that same steps with the OSGeo4W environment and got the same results.
> Does it means that there is something wrong with the data folder in 1.9 or is that part of a new approach of dealing with that particular kind of projection?
> Regards,
> Ivan
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
and watch the world go round - Rush | Geospatial Software Developer
