[gdal-dev] OGR support for VPF DNC?
Andreas Oxenstierna ao at t-kartor.se
Wed Apr 11 02:56:00 EDT 2012
Chaitanya,
Same result with 1.8.0
With some effort we can test with 1.9, as we have not found any
OGDI-compiled OGR for 1.9
Then also I assume we can insert debug-flags to maybe get more
information. We have experimented with the Java bindings (jar) as we
will integrate OGR with a Java servlet.
Best Regards
Andreas
> Andreas,
> Could you first test your data with the latest version of GDAL? The
> latest Windows binaries can be obtained through the OSGeo4W installer.
> In any case, I couldn't find any reference to DNC in the OGDI library,
> which is used by OGR to read VPF files.
> On Tue, Apr 10, 2012 at 5:22 PM, Andreas Oxenstierna <ao at t-kartor.se
> <mailto:ao at t-kartor.se>> wrote:
>     I cannot make OGR work with VPF DNC data.
>     ogrinfo and ogr2ogr crashes when trying to read data from any
>     level inside the VPF structure. DHT and LAT files do exist.
>     OGR does work for standard VMAP0 and VMAP1 data.
>     Is this a known limitation?
>     Does DNC require some special syntax?
>     I have used e.g. ogrinfo gltp:/vrf/C:\xxx and ogrinfo gltp:/vrf/C:/xxx
>     Tested version:
>     1.7.0b2 as included in FWTools 2.4.7 on Windows
>     I noted that only FME seems to be able to always correctly read
>     the DNC data we have available. For example vpfview, nimamuse and
>     ArcGIS do have various issues.
>     Best Regards
>     Andreas Oxenstierna
>     T-Kartan Produkt AB
>     mobile: +46 733 206831 <tel:%2B46%20733%20206831>
>     mailto: ao at t-kartor.se <mailto:ao at t-kartor.se>
>     http://www.t-kartor.com
>     _______________________________________________
>     gdal-dev mailing list
>     gdal-dev at lists.osgeo.org <mailto:gdal-dev at lists.osgeo.org>
>     http://lists.osgeo.org/mailman/listinfo/gdal-dev
> Best regards,
> Chaitanya kumar CH.
> +91-9494447584
> 17.2416N 80.1426E
Andreas Oxenstierna
T-Kartan Produkt AB
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20120411/84284399/attachment.html
