[gdal-dev] VRT - using 8BPP palettized tiles
Chaitanya kumar CH chaitanya.ch at gmail.com
Wed Apr 11 04:55:14 EDT 2012
Oyvind,
VRT does support colortable expansion.
Check out the ComplexSource sub-topic in the vrt doc page[1].
> From the The ComplexSource supports fetching a color component from a
> source raster band that has a color table. The ColorTableComponent value is
> the index of the color component to extract : 1 for the red band, 2 for the
> green band, 3 for the blue band or 4 for the alpha band.
[1]: http://www.gdal.org/gdal_vrttut.html
On Wed, Apr 11, 2012 at 1:27 PM, Oyvind Idland <oyvind.idland at gmail.com>wrote:
> Hello,
> I am fiddling with some old scanned (handmade) maps. In order to reduce
> the size of the data, and since
> the maps has a limited amount of colors, i figured that using palettized
> 8BPP tiffs would be suitable in this
> case.
> I got several tiles that make up the whole area, using rgb(0,0,0) as
> nodata (making JPEG compression
> unsuitable)
> The idea was to use VRT to join these together, but since they all have
> different color tables,
> this is not possible.
> Would it be an idea to implement support for an "expand option" in VRT,
> e.g expanding to rgb/rgba ?
> Not sure how many would need this feature though.
> -- oyvind
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
Best regards,
Chaitanya kumar CH.
+91-9494447584
17.2416N 80.1426E
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20120411/31dd6ed6/attachment-0001.html
