[gdal-dev] version mixup on ubuntu 10.04 - Solved
Zoltan Szecsei zoltans at geograph.co.za
Wed Apr 11 12:37:22 EDT 2012
On 2012/04/11 10:16, Zoltan Szecsei wrote:
> Hi,
> I seem to have a mixup with different versions of gdal
>> ogr2ogr --version
>> ogr2ogr: /usr/local/lib/libgdal.so.1: no version information
>> available (required by ogr2ogr)
>> ERROR 1: ogr2ogr was compiled against GDAL 1.9 but current library
>> version is 1.8
>> zls at gs0:~$ which ogr2ogr
>> /usr/bin/ogr2ogr
> I think some time back I installed QGIS, etc.
> More recently I downloaded gdal 1.9 and compiled it, only to get the
> above problem.
> I then used apt-get remove to clean up, re-installed gdal 1.9 and
> still the same problem.
> How do I clean up entirely, so that I can get a clean install?
> If I re-install QGIS etc, using apt, can I then upgrade the gdal part
> of this install to 1.9?
> Or do I uninstall QGIS totally and then run only with gdal.
> (I hardly ever use QGIS in Linux, but often use the gdal/ogr command
> line utilities)
> TIA,
> Zoltan
I just ditched QGIS, recompiled gdal, and all's good.
Thanks,
Zoltan
Zoltan Szecsei PrGISc [PGP0031]
Geograph (Pty) Ltd.
P.O. Box 7, Muizenberg 7950, South Africa.
65 Main Road, Muizenberg 7945
Western Cape, South Africa.
34° 6'16.35"S 18°28'5.62"E
Tel: +27-21-7884897  Mobile: +27-83-6004028
Fax: +27-86-6115323     www.geograph.co.za
