[gdal-dev] broken trunk build on Win
Even Rouault
even.rouault at mines-paris.org
Thu Apr 12 09:07:19 EDT 2012
Selon Joaquim Luis <jluis at ualg.pt>:
> Hi,
> I made some false reports in the past about the build failures that
> ended up being caused by no starting by a "make clean", but that is not
> the case this time.
> I'm getting these errors on linking the current head.
There must be something particular in your setup. I can see that MSVC2010 on
Win64 builds fine on Tamas Szekeres daily builds. See
http://www.gisinternals.com/sdk . Your errors look like something with linking
options.
