[gdal-dev] Apply filter on VRT
Chaitanya kumar CH
chaitanya.ch at gmail.com
Thu Apr 12 09:56:58 EDT 2012
Saâd,
Can you provide the vrt file causing the crash? Also, please show me the
error messages you got.
On Thu, Apr 12, 2012 at 7:21 PM, Saâd HESSANE <saad.hessane at gmail.com>wrote:
> Thank you Chaitanya for the answer,
> I do the test with the kenel element like the documentation :
>> <Kernel normalized="1">
>> <Size>3</Size>
>> <Coefs>0.11111111 0.11111111 0.11111111 0.11111111 0.11111111
>> 0.11111111 0.11111111 0.11111111 0.11111111</Coefs>
>> </Kernel>
> It's the same probleme, gdal_translate crash. But if the VRTRasterBand
> have just one KernelFilteredSource element, gdal_translate work fine and
> apply the filtre correctely.
> The poblem appears if there are more than one KernelFilteredSource element
> in the VRTRasterBand.
> 2012/4/12 Chaitanya kumar CH <chaitanya.ch at gmail.com>
>> Saâd,
>> There should be a Kernel element in a KernelFilteredSource.
>> FYI, all the pixels whose kernel has a nodata pixel will be reported as a
>> nodata pixel.
>> On Wed, Apr 11, 2012 at 3:20 PM, Saâd HESSANE <saad.hessane at gmail.com>wrote:
>>> Hy all,
>>> I have a VRT file generated with buildvrt utility :
>>> <VRTDataset rasterXSize="52436" rasterYSize="32400">
>>>> <SRS>...</SRS>
>>>> <GeoTransform>...</GeoTransform>
>>>> <VRTRasterBand dataType="UInt16" band="1">
>>>> <NoDataValue>0</NoDataValue>
>>>> <ColorInterp>Gray</ColorInterp>
>>>> <ComplexSource>
>>>> <SourceFilename relativeToVRT="1">1.tif</SourceFilename>
>>>> <SourceBand>1</SourceBand>
>>>> <SourceProperties RasterXSize="8449" RasterYSize="6429"
>>>> DataType="UInt16" BlockXSize="8449" BlockYSize="1" />
>>>> <SrcRect xOff="0" yOff="0" xSize="8449" ySize="6429" />
>>>> <DstRect xOff="0" yOff="0" xSize="10721" ySize="8158" />
>>>> <NODATA>0</NODATA>
>>>> </ComplexSource>
>>>> <ComplexSource>
>>>> <SourceFilename relativeToVRT="1">2.tif</SourceFilename>
>>>> <SourceProperties RasterXSize="8772" RasterYSize="6407"
>>>> DataType="UInt16" BlockXSize="8772" BlockYSize="1" />
>>>> <SrcRect xOff="0" yOff="0" xSize="8772" ySize="6407" />
>>>> <DstRect xOff="43664" yOff="25993" xSize="8772" ySize="6407" />
>>>> <NODATA>0</NODATA>
>>>> </ComplexSource>
>>>> </VRTRasterBand>
>>>> </VRTDataset>
>>> It's work fine with a gdal_translate.
>>> Now I want to apply a filter kernel to the VRT. I have to use the
>>> The gdal api say that VRTKernelFilteredSource is a sub-class of
>>> VRTComplexSource. So a VRTKernelFilteredSource *is *a VRTComplexSource.
>>> But if I replace VRTComplexSource by VRTKernelFilteredSource,
>>> gdal_translate crash. This is the new VRT :
>>>> <SRS>...</SRS>
>>>> <KernelFilteredSource>
>>>> <NODATA>0</NODATA>
>>>> </KernelFilteredSource>
>>>> <NODATA>0</NODATA>
>>>> </VRTRasterBand>
>>>> </VRTDataset>
>>> It's weird, I expected a polymorphism between VRTComplexSource and
>>> VRTKernelFilteredSource.
>>> So the question : how can I apply a filter to a VRT?
>>> Thank you !
>>> gdal-dev mailing list
>>> gdal-dev at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
>> Best regards,
>> Chaitanya kumar CH.
>> +91-9494447584
>> 17.2416N 80.1426E
Best regards,
Chaitanya kumar CH.
+91-9494447584
17.2416N 80.1426E
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20120412/1bc86579/attachment-0001.html
