[gdal-dev] NODATA value in rasters
Frank Warmerdam
warmerdam at pobox.com
Fri Apr 13 15:50:03 EDT 2012
David,
Some formats support identifying a particular pixel value as nodata
and some do not.
When they don't and you write nodata, we usually try to store the
information in an
.aux.xml file (auxilary metadata) which at least GDAL based applications would
recognise.
Best regards,
Frank
On Fri, Apr 13, 2012 at 12:07 PM, David Strip <gdal at stripfamily.net> wrote:
> What data formats besides geotiff support a NODATA value? Is there a
> uniform GDAL approach to determining the NODATA value or otherwise
> determining if a pixel is a NODATA pixel? I know that this value is stored
> in a geotiff tag, but that won't work for other formats.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
and watch the world go round - Rush | Geospatial Software Developer
