[gdal-dev] NODATA value in rasters
David Strip
gdal at stripfamily.net
Fri Apr 13 18:56:23 EDT 2012
On 4/13/2012 1:50 PM, Carl Godkin wrote:
> I think a lot of formats support the concept of NODATA. The GDAL API
> has functions for checking for this in the GDALRasterBand class, for
> instance, as
> double GDALRasterBand::GetNoDataValue() in the C++ or in the C API
> as GDALGetRasterNoDataValue().
> I've found that this sometimes works, but not always. What I do is to
> read the raster data and change everything outside the minimum to
> maximum range (returned by two other API functions) to my own
> software's NODATA value.
> Hope that helps,
> carl
Yes, that helps a lot. I'm not sure how I missed
GDALRasterBand::GetNoDataValue() in my searches, but at least now I know
how to address the problem I was dealing with.
Thanks.
