[gdal-dev] Multi image segments in NITF file
Livneh Yehiyam yehil at rafael.co.il
Mon Apr 16 11:24:44 EDT 2012
Even
I will create a ticket and patch tomorrow.
Thanks
-----Original Message-----
From: Even Rouault [mailto:even.rouault at mines-paris.org]
Sent: Monday, April 16, 2012 6:06 PM
To: Livneh Yehiyam
Cc: gdal-dev; Even Rouault; Livneh Yehiyam
Subject: Re: [gdal-dev] Multi image segments in NITF file
Selon Livneh Yehiyam <yehil at rafael.co.il><table align='center'><tr><td></td></tr></table>:
> Hi Even and list
> Regarding the creation of NITF image segments (see below):
> We've added this functionality as you suggested using the creation options.
> For our purpose it works great. We are now able to create an NITF file with
> multiple image segments (each with a different size, color format, etc.).
> We have made the changes against the 1.8.1 version (not trunk or 1.9) since
> this is what we currently use.
> Do you think it is something you will be interested in adding to GDAL? If so,
> what do you need? Will a patch against the 1.8.1 version is enough?
Hi Livneh,
A ticket against trunk would be preferable for easier integration, but a patch
against 1.8.1 is better than nothing, at least for the reviewing step. Please
create a ticket in Trac so it doesn't get lost.
Thanks,
Even
This message (including any attachments) issued by RAFAEL- ADVANCED DEFENSE SYSTEMS LTD.
(hereinafter "RAFAEL") contains confidential information intended for a specific individual and purpose, may
constitute information that is privileged or confidential or otherwise protected from disclosure. If you are not
the intended recipient, you should contact us immediately and thereafter delete this message from your
system. You are hereby notified that any disclosure, copying, dissemination, distribution or forwarding of this
message, or the taking of any action based on it, is strictly prohibited. If you have received this e-mail in error,
please notify us immediately by e-mail mailto:lawraf at rafael.co.il and completely delete or destroy any and all
electronic or other copies of the original message and any attachments thereof.
