[gdal-dev] gdal_translate crash on certain filenames
Jay Jennings
Jennings.Jay at geoeye.com
Tue Apr 17 18:11:30 EDT 2012
Hi List,
We have encountered something really strange in our GDAL build (1.9.0, built from source on Windows 7 64-bit). It appears that "gdal_translate" crashes (i.e. Windows popup dialog that says "gdal_translate has stopped working...") when the output filename starts with certain strings. It seems that the input file can be a random GeoTiff with a random name and path - the killer seems to be the *output* filename.
--- These commands result in the crash:
gdal_translate -of GTiff -co tiled=yes F:\PreIngest\junk2.tif C:\Temp\TSX1_SAR.tif
gdal_translate -of GTiff -co tiled=yes F:\PreIngest\junk2.tif C:\Temp\TDX1_SAR.tif
Whereas that same command finishes without a problem, if the output filename is changed to "TAX1_SAR.tif" or "TDX2_SAR.tif" or "TDX1_SA.tif"
Our experiments indicate the command will fail anytime the output filename starts with the strings "TDX1_SAR" or "TSX1_SAR". Can anyone out there duplicate this ? In general, GDAL has been quite reliable for us - this is probably the strangest thing we've seen.
Jay Jennings
Senior Software Developer
GeoEye, Inc.
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20120417/75ca0e58/attachment.html
