[gdal-dev] Very large time difference using gdal_translate from
Jpeg2000 to different formats using JP2KAK driver
Adam Brown
adam.brown at arcitecta.com
Wed Apr 18 01:04:27 EDT 2012
On 15/04/12 2:48 PM, Frank Warmerdam wrote:
> On 12-04-12 05:53 PM, ahbrown wrote:
>> Hi,
>> I am wondering why there is such a large difference in the time to
>> convert a
>> large O(250MB) Jpeg2000 image to GeoTiff format in comparison with
>> conversion to other formats (e.g. jpeg, png)?
>> I am using the Kakadu Jpeg2000 driver. With a 43221 x 36021 Jpeg2000
>> image.
>> Results of timed conversions are as follows:
>> Using RasterIO directly (via the Java wrapper) the conversion takes
>> around 6
>> seconds.
> Adam,
> Many drivers implement the CreateCopy() rather than Create() method.
> In these
> cases the input dataset is passed to the output driver and they pull
> data in
> whatever way is convenient.
> The PNG and JPEG drivers are "CreateCopy" drivers and likely request data
> one scanline at a time. In this situation the JP2KAK driver actually
> gets
> asked for the data in moderate sized tiles which turns out not to be very
> efficient for the Kakadu library as there is a high setup cost for each
> windowed read.
> The GeoTIFF format support Create(), so gdal_translate is able to more
> closely manage the chunking of reads and writes and tries to do it in
> large chunks. The JP2KAK driver handles large reads through IRasterIO()
> as single windowed reads which are more efficient than the smaller tile
> reads.
> So I think the bulk of the difference in performance is related to
> different
> IO strategies that apply against the JP2KAK driver. The variation
> between
> JPEG and PNG times is likely different costs on the compression side.
> PS. it appears posts through nabble do not preserve some components, like
> the fixed font timings text. I encourage direct use of the mailing list
> for posts.
> Best regards,
Hi Frank and Chaitanya,
Thanks for the quick response.
What doesn't make sense to me is that I can perform the same JP2->PNG translation benchmarked below in a little over 6 seconds using the GDAL Java wrappers.
Most of this is spent in the read/subsample operation. The write to the 200x200 png takes only 20 ms.
So gdal_translate is adding 8-12s of overhead somewhere.
I've posted the timings again below as they were stripped out from the original post:
time gdal_translate -of GTiff -outsize 200 200 master_original.jp2 master_original.tif
real 0m2.325s
time gdal_translate -of JPEG -outsize 200 200 master_original.jp2 master_original.jpg
real 0m18.317s
time gdal_translate -of PNG -outsize 200 200 master_original.jp2 master_original.png
user 0m14.588s
GDAL Java wrapper (same JP2 to 200x200 PNG): approx 6s
Regards,
Adam
