[gdal-dev] Magic number 441?
Anton Korosov
anton.korosov at nersc.no
Wed Apr 18 09:18:10 EDT 2012
Dear list, thank you for not replying - it made me happier when I
discovered the error myself ;)
If gdalwarp is used with '-geoloc' and '-off VRT' and SRC image covers
only part of the DST image and block size is small enough to allow one
of the blocks to be completely outside the SRC image then gdaltranslate
of the generated VRT file fails. That's obviously an error and I will
create a ticket with examples and debugging output.
So the solution for the problem is to set the BlockSize to the image size.
With best regards!
Anton
On 04/16/2012 12:12 PM, Anton Korosov wrote:
> Dear list,
> what does the annoying error 'ERROR 1: Too many points (441 out of 441)
> failed to transform' mean?
> When I try to warp a MODIS image directly into tif it works perfect:
> gdalwarp -t_srs '+proj=latlong' -of GTiff -geoloc -te -4 51 14 66 -ts
> 900 1400 HDF4_SDS:UNKNOWN:"/data/A2012101111000.L2_LAC.NorthSea.hdf":15
> modis_geoloc.tif
> But when I try to make the VRT file first it fails with this error:
> Commands:
> gdalwarp -t_srs '+proj=latlong' -of VRT -geoloc -te -4 51 14 66 -ts 900
> modis_geoloc.vrt
> gdal_translate modis_geoloc.vrt modis_geoloc.vrt.tif
> Output:
> Input file size is 900, 1400
> 0ERROR 1: Too many points (441 out of 441) failed to transform,
> unable to compute output bounds.
> ERROR 1: modis_geoloc.vrt, band 1: IReadBlock failed at X offset 0, Y
> offset 0
> ERROR 1: GetBlockRef failed at X block offset 0, Y block offset 0
> What makes me crazy is that if the output file is smaller (say 500 x
> 500) it works via the VRT also fine. WHY?!
> The VRT file (w/o metadata) is below. The source file (4 MB) is here:
> http://hab.nersc.no/NorthSea/A2012101111000.L2_LAC.NorthSea.hdf.bz2
> Thank you very much for any hint.
> Anton
> <VRTDataset rasterXSize="900" rasterYSize="1400"
> subClass="VRTWarpedDataset">
> <SRS>GEOGCS["WGS
> 84",DATUM["unknown",SPHEROID["WGS84",6378137,298.257223563]],PRIMEM["Greenwich",0],UNIT["degree",0.0174532925199433]]</SRS>
> <GeoTransform> -4.0000000000000000e+00, 2.0000000000000000e-02,
> 0.0000000000000000e+00, 6.6000000000000000e+01, 0.0000000000000000e+00,
> -1.0714285714285714e-02</GeoTransform>
> <Metadata>
> <MDI key="bad_value_scaled">-32767</MDI>
> </Metadata>
> <VRTRasterBand dataType="Int16" band="1" subClass="VRTWarpedRasterBand">
> <ColorInterp>Gray</ColorInterp>
> </VRTRasterBand>
> <BlockXSize>512</BlockXSize>
> <BlockYSize>128</BlockYSize>
> <GDALWarpOptions>
> <WarpMemoryLimit>6.71089e+07</WarpMemoryLimit>
> <ResampleAlg>NearestNeighbour</ResampleAlg>
> <WorkingDataType>Int16</WorkingDataType>
> <Option name="INIT_DEST">0</Option>
> <SourceDataset
> relativeToVRT="1">HDF4_SDS:UNKNOWN:/data/A2012101111000.L2_LAC.NorthSea.hdf:15</SourceDataset>
> <Transformer>
> <ApproxTransformer>
> <MaxError>0.125</MaxError>
> <BaseTransformer>
> <GenImgProjTransformer>
> <SrcGeoLocTransformer>
> <GeoLocTransformer>
> <Reversed>0</Reversed>
> <Metadata>
> <MDI key="LINE_OFFSET">0</MDI>
> <MDI key="LINE_STEP">1</MDI>
> <MDI key="PIXEL_OFFSET">0</MDI>
> <MDI key="PIXEL_STEP">1</MDI>
> <MDI key="SRS">GEOGCS["WGS 84",DATUM["WGS_1984",SPHEROID["WGS
> 84",6378137,298.257223563,AUTHORITY["EPSG","7030"]],TOWGS84[0,0,0,0,0,0,0],AUTHORITY["EPSG","6326"]],PRIMEM["Greenwich",0,AUTHORITY["EPSG","8901"]],UNIT["degree",0.0174532925199433,AUTHORITY["EPSG","9108"]],AUTHORITY["EPSG","4326"]]</MDI>
> <MDI key="X_BAND">1</MDI>
> <MDI
> key="X_DATASET">HDF4_SDS:UNKNOWN:"/data/A2012101111000.L2_LAC.NorthSea.hdf":11</MDI>
> <MDI key="Y_BAND">1</MDI>
> <MDI
> key="Y_DATASET">HDF4_SDS:UNKNOWN:"/data/A2012101111000.L2_LAC.NorthSea.hdf":12</MDI>
> </Metadata>
> </GeoLocTransformer>
> </SrcGeoLocTransformer>
> <DstGeoTransform>-4,0.02,0,66,0,-0.01071428571428571</DstGeoTransform>
> <DstInvGeoTransform>200,49.99999999999999,0,6159.999999999999,0,-93.33333333333333</DstInvGeoTransform>
> <ReprojectTransformer>
> <ReprojectionTransformer>
> <SourceSRS>GEOGCS["WGS 84",DATUM["WGS_1984",SPHEROID["WGS
> 84",6378137,298.257223563,AUTHORITY["EPSG","7030"]],TOWGS84[0,0,0,0,0,0,0],AUTHORITY["EPSG","6326"]],PRIMEM["Greenwich",0,AUTHORITY["EPSG","8901"]],UNIT["degree",0.0174532925199433,AUTHORITY["EPSG","9108"]],AUTHORITY["EPSG","4326"]]</SourceSRS>
> <TargetSRS>GEOGCS["WGS
> 84",DATUM["unknown",SPHEROID["WGS84",6378137,298.257223563]],PRIMEM["Greenwich",0],UNIT["degree",0.0174532925199433]]</TargetSRS>
> </ReprojectionTransformer>
> </ReprojectTransformer>
> </GenImgProjTransformer>
> </BaseTransformer>
> </ApproxTransformer>
> </Transformer>
> <BandList>
> <BandMapping src="1" dst="1" />
> </BandList>
> </GDALWarpOptions>
> </VRTDataset>
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
