[gdal-dev] Layer operations, a proposal
Ari Jolma ari.jolma at gmail.com
Thu Apr 19 09:05:04 EDT 2012
On 04/19/2012 03:04 PM, Even Rouault wrote:
>> http://trac.osgeo.org/gdal/wiki/rfc39_ogr_layer_algebra
> 3) I'm wondering if it would not be more appropriate to separate the creation of
> fields of the output layer in a separate method that might be called, or not,
> before the real operation. For example IdentifyPrepare() for Identity().
I don't understand your reasoning behind this. I get the point of
separating the field map computations, but don't see why or how that
would necessitate the *Prepare methods.
> This way the XXXXXPrepare() would not need to check that CreateField()
> succeeds because XXXX() could work with an output layer with no fields at all.
> Checking that there are not fields with same name would not be necessary (in
> that case the value from B would override the value from A).
It is possible to have fields with same names in OGR. Having a field
with same name does not mean that they are semantically same. Probably
more often not. I think the method could be easier to understand if
there is no value override. Simpler the better. The only thing I'd check
is that the result layer does not have any fields before the method.
Other comments are fine, thanks.
Ari
