[gdal-dev] How to change variable names in netCDF?
blaa_katt at yahoo.co.jp blaa_katt at yahoo.co.jp
Thu Apr 19 10:09:36 EDT 2012
Normal  0          false  false  false    EN-US  JA  X-NONE                                          MicrosoftInternetExplorer4        /* Style Definitions */ table.MsoNormalTable	{mso-style-name:"Table Normal";	mso-tstyle-rowband-size:0;	mso-tstyle-colband-size:0;	mso-style-noshow:yes;	mso-style-priority:99;	mso-style-qformat:yes;	mso-style-parent:"";	mso-padding-alt:0cm 5.4pt 0cm 5.4pt;	mso-para-margin-top:0cm;	mso-para-margin-right:0cm;	mso-para-margin-bottom:10.0pt;	mso-para-margin-left:0cm;	line-height:115%;	mso-pagination:widow-orphan;	font-size:11.0pt;	font-family:"Calibri","sans-serif";	mso-ascii-font-family:Calibri;
	mso-ascii-theme-font:minor-latin;	mso-hansi-font-family:Calibri;	mso-hansi-theme-font:minor-latin;	mso-bidi-font-family:"Times New Roman";	mso-bidi-theme-font:minor-bidi;}
Hello,
Thank you for the reply, Etienne.
If it is impossible with the gdal 1.9.0,I would like to implement some modifications.
We found netCDF constructor in netcdfdataset.cpp.
I think it is possible to modify the names by setting pszBandNameas shown follows:
    if (!pszBandName || EQUAL(pszBandName,"")  )
        sprintf( szTemp, "Band%d", nBand );
    else
        strcpy( szTemp, pszBandName );
            CPLDebug( "GDAL_netCDF","nc_def_var(%d,%s,%d)",
                      cdfid, szTemp,nc_datatype );
            status = nc_def_var( cdfid, szTemp,nc_datatype,
                         NCDF_NBDIM,anBandDims, &nZId );
But the course of the modification is unclear for me.
Can anyone give me any advice which way is better,  (e.g. parsing of names through string options,making reserved metadata with a name, modification of Python APIs, etc)?
Kind regards,
Asuka
Etienne Tourigny <etourigny.dev at gmail.com> wrote:
If you use gdal-1.9 the driver will use the variable name from the
original netcdf file (if any).
for example, if you use the following command the original filename
will be preserved.
gdal_translate -of netcdf in.nc out.nc
However, if copying from other formats (such as gtiff), or creating a
new netcdf file, there is no way to change the variable name with
gdal.
You can use other tools such as:
NCO -> nco.sourceforge.net/
cdo ->https://code.zmaw.de/projects/cdo
Etienne
On Thu, Apr 19, 2012 at 5:15 AM,  <blaa_katt at yahoo.co.jp> wrote:
> Hello everybody,
> I have a question about netCDF creation.
> I am using GDAL 1.9.0 in python.
> Creation Issues in http://www.gdal.org/frmt_netcdf.html mentions
> “each variable array is names Band1, Band2,… ”.
> I would like to change the names.
> Can anyone give me ideas?
> Thank you for your time.
> Kind regards,
> Asuka
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20120419/46095166/attachment-0001.html
