[gdal-dev] Enabling DAP appears to disable several other formats
Charlie Sharpsteen
chuck at sharpsteen.net
Thu Apr 19 21:20:51 EDT 2012
I'm trying to add support for OpenDAP to a build of GDAL on OS X. However,
when I add `--with-dods-root` to my configure arguments,
I inexplicably loose support for Epsilon, cURL, SpatiaLite and FreeXL.
Full configure logs can be found here:
https://gist.github.com/2425147
The diff between the configure output before and after adding DAP is:
diff --git a/gdal_without_dap.log b/gdal_with_dap.log
index 2eb06b3..405300f 100644
--- a/gdal_without_dap.log
+++ b/gdal_with_dap.log
@@ -244,17 +244,22 @@ checking for Google libkml... yes
checking if Google libkml version is >= 1.3.0... no
using odbc library from /usr/local.
checking if Oracle support is enabled... no
-checking Checking for DODS... disabled
+checking Checking for DODS... libdap < 3.10
+libdap >= 3.9
+setting DODS root directory to /usr/local
found libcurl version 7.19.7
-checking for curl_global_init in -lcurl... yes
-checking for spatialite_init in -lspatialite... yes
-enabled
+checking for curl_global_init in -lcurl... no
+checking for spatialite_init in -lspatialite... no
+disabled
+checking for sqlite3_open in -lsqlite3... yes
+checking for SQLite3 library >= 3.0.0... yes
checking Checking for DWGdirect... disabled
configure: "IBM Informix DataBlade support disabled."
configure: checking whether we should include ESRI SDE support...
ESRI SDE support not requested.
checking for VFK support... yes
-checking for eps_read_block_header in -lepsilon... yes
+checking for eps_read_block_header in -lepsilon... no
+libepsilon not found - EPSILON support disabled
checking for geos-config... /usr/local/bin/geos-config
checking for GEOS version >= 2.2.0... yes
checking for GEOSversion in -lgeos_c... yes
@@ -263,7 +268,10 @@ checking for OpenCL support... no
checking for FreeXL support... checking freexl.h usability... yes
checking freexl.h presence... yes
checking for freexl.h... yes
-checking for freexl_open in -lfreexl... yes
+checking for freexl_open in -lfreexl... no
+libfreexl not found - FreeXL support disabled
checking whether to enable PAM... yes
checking for poppler... yes
checking if Catalog::optContent exists... yes
@@ -318,9 +326,9 @@ GDAL is now configured for i386-apple-darwin10.8.0
MrSID/MG4 Lidar support: no
MSG support: no
GRIB support: yes
- EPSILON support: yes
+ EPSILON support: no
WebP support: no
- cURL support (wms/wcs/...):yes
+ cURL support (wms/wcs/...):no
PostgreSQL support: yes
MySQL support: no
Ingres support: no
@@ -337,9 +345,9 @@ GDAL is now configured for i386-apple-darwin10.8.0
GEORASTER support: no
SDE support: no
Rasdaman support: no
- DODS support: no
+ DODS support: yes
SQLite support: yes
- SpatiaLite support: yes
+ SpatiaLite support: no
DWGdirect support no
INFORMIX DataBlade support:no
GEOS support: yes
@@ -348,7 +356,7 @@ GDAL is now configured for i386-apple-darwin10.8.0
Podofo support: no
OpenCL support: no
Armadillo support: no
- FreeXL support: yes
+ FreeXL support: no
Mac OS X Framework : no
Any ideas why providing configure with the info to find one package is
hosing four unrelated packages?
Thanks!
-Charlie
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20120419/385da75d/attachment.html
