[gdal-dev] available opensource geoprocessing code based on GDAL
Pirmin Kalberer
pi_ml at sourcepole.com
Fri Apr 20 07:33:02 EDT 2012
Am Donnerstag, 19. April 2012, 03.57:45 schrieb chenliang wang:
> Hi,all:
> I am going to write a platform to process some geospatial data based on
> GDAL. But I noticed I need to write so many geoprocessing code by
> myself. Is there any availabe GDAL geoprocessing codes that is similar
> with ArcGIs geoprocessing tools? Thanks
QGIS with the brand new SEXTANTE processing framework plugin might be what you
are looking for. You can add your own processing steps based on the Python
GDAL interface.
Regards
Pirmin
Pirmin Kalberer
Sourcepole - Linux & Open Source Solutions
http://www.sourcepole.com
