[gdal-dev] RFC 39
Ari Jolma ari.jolma at gmail.com
Wed Apr 25 11:11:17 EDT 2012
On 04/25/2012 04:31 PM, Even Rouault wrote:
> Hi Ari,
> Hum, I'm surprised that it has survived your testing ;-) : GetSpatialFilter()
> might return NULL (in fact, in the general case, it will), so
> GetSpatialFilter()->clone() should segfault.
I've not yet tested this one at all :) -- I only made sure it compiles.
I'll address the issues below later.
The autotests are in Python, I believe. Any volunteers for writing those?
Ari
hm, seems I failed to start a new thread since at least Thunderbird puts
this into the old one.
> CPLMalloc() cannot return NULL. Internally, it will abort if the memory
> allocation failed. So you can just remove the if (!mapInput) // if (!mapMethod)
> tests afterwards, or use VSIMalloc() instead. For consistency, memory allocated
> with CPLMalloc()/VSIMalloc() should be freed with CPLFree()/VSIFree(), and not
> free(). (There's an alternate memory allocator that does consistency checking
> that can be enabled by defining #define DEBUG_VSIMALLOC in
> port/cpl_vsisimple.cpp)
> For the final implementation, the new methods that are the object of the RFC
> will need Doxygen doc.
> I don't see a strong reason to publish OGR_F_SetFieldsFromWithMap() in the C
> API. This is mostly usefull for internal purposes for now.
> About SetFieldsFrom(), it also changes SetFID() and SetStyleString(). This is a
> bit counter-intuitive. It will be indeed interesting to make SetFeatureFrom()
> call SetFeatureFrom() to avoid code duplication.
> As far as the RFC is concerned, do you intend writing tests in the autotest
> suite for the new methods ?
> Best regards,
> Even
