[gdal-dev] gdaladdo level values
Frank Warmerdam
warmerdam at pobox.com
Thu Apr 26 14:01:25 EDT 2012
On Thu, Apr 26, 2012 at 10:42 AM, Richard Nicoll
<richardnicoll at gmail.com> wrote:
> Hi guys
> I am new to using GDAL so apologies if this is a silly question!
> When using the gdaladdo to create GeoTIFF pyramid layers (overviews),
> can the levels values be decimal values, or do they have to be
> integers? I have tried using decimals (e.g. 4.3) since this will
> produce an overview at the exact required scale for the viewing app,
> however GDAL appears to be rounding up/down to the closest whole
> number!
Richard,
I can confirm that the BuildOverviews() api only supports
integer overview levels. I do believe that GDAL can support
reading overviews, even at non-integer overview levels, but not
create them.
Best regards,
and watch the world go round - Rush | Geospatial Software Developer
