[gdal-dev] compiling gdal 1.9 with FGDB support
Eric Goddard egoddard1010 at gmail.com
Sat Apr 28 11:47:33 EDT 2012
Thanks again Even, it worked that time. I should've specified which version
of the FGDB API I'm using. The library names were so similar I didn't even
notice the difference in the error message.
Eric
On Sat, Apr 28, 2012 at 10:22 AM, Even Rouault <even.rouault at mines-paris.org
> wrote:
> Le samedi 28 avril 2012 17:14:56, Eric Goddard a écrit :
> > Thanks for the response, Even. I updated the ld path and ran ldconfig,
> and
> > reran configure and make with the same options as before, but I received
> > this error message again:
> > /usr/bin/ld: cannot find -lfgdblinuxrtl
> > collect2: ld returned 1 exit status
> > make[1]: *** [libgdal.la] Error 1
> > make[1]: Leaving directory `/home/eric/Downloads/gdal-1.9.0'
> > make: *** [check-lib] Error 2
> > Running ldconfig -v outputs:
> > /usr/local/FileGDB_API/lib:
> >     libFileGDBAPI.so -> libFileGDBAPI.so
> >     libfgdbunixrtl.so -> libfgdbunixrtl.so
> > So it looks like ld finds libfgdbunixrtl.so...
> Ah, I guess you use FileGDB API 1.2. There was a change in ESRI delivery
> between FileGDB API 1.1 and 1.2. They renamed libgdblinuxrtl.so into
> libfgdbunixrtl.so. Support for FileGDB API 1.2 will be fixed in next-to-be-
> released 1.9.1 (see http://trac.osgeo.org/gdal/ticket/4570 ). In the
> meantime,
> you can create a symlink, like that :
> sudo ln -s /usr/local/FileGDB_API/lib/libfgdbunixrtl.so
> /usr/local/FileGDB_API/lib/libfgdblinuxrtl.so
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20120428/36c16889/attachment.html
