[gdal-dev] Units of dimension variable in NetCDF is 'km'
Kyle Shannon
kyle at pobox.com
Tue Aug 7 06:59:31 PDT 2012
What version are you using? I seem to remember something like this in a
ticket I filed. I thought it was fixed in 1.9.1.
kss
On Tue, Aug 7, 2012 at 5:38 AM, Etienne Tourigny <etourigny.dev at gmail.com>wrote:
> Hi,
> km units are supposed to work...
> Here is the code where "km" units are detected, which set the WKT
> units to 1000m.
> /* add units to PROJCS */
> if ( pszUnits != NULL && ! EQUAL(pszUnits,"") ) {
> if ( EQUAL(pszUnits,"m") ) {
> oSRS.SetLinearUnits( CF_UNITS_M, 1.0 );
> oSRS.SetAuthority( "PROJCS|UNIT", "EPSG", 9001 );
> else if ( EQUAL(pszUnits,"km") ) {
> oSRS.SetLinearUnits( CF_UNITS_M, 1000.0 );
> What does the wkt actually look like?
> Also running gdalinfo --debug ON <file.nc> can give a few hints.
> It would be good for you to send me a link to the file or attach it to
> a bug report (add me as cc).
> Etienne
> On Tue, Aug 7, 2012 at 6:10 AM, Anton Korosov <anton.korosov at nersc.no>
> wrote:
> > Dear Etienne,
> > I faced the following problem with the NetCDF driver:
> > Units of the dimension variables are 'km' and values in the SRS are in
> > meters, of course (e.g. Earth radius). Hence the calculated GeoTransform
> is
> > 1000 times less than should be and the calculate latlons are incorrect.
> > However 'units' attribute is given, besides AFAIK CF-conventions allow to
> > have 'k' (kilo) preceding 'm' (meters) in the units.
> > Can you please give me a hint where to fix that in the driver so that it
> can
> > adequately interpret units of the dimensions?
> > With best regards!
> > Anton
> > gdal-dev mailing list
> > gdal-dev at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20120807/7b25b920/attachment.html>
