[gdal-dev] ogr_OCI plugin can't find OCI.dll
Ivan Lucena ivan.lucena at princeton-ma.us
Thu Aug 9 07:17:24 PDT 2012
Hi Paul,
I am not sure I understood the question but what I know is that your PATH variable should have the folder where OCI.DLL is installed. For example:
C:\> echo %PATH%
<some folder here>;C:\Oracle11\product\11.2.0\dbhome_1\bin\oci.dll;<some folder here>
You might *not* have an Oracle client, Instant Client or Server installed on your system.
That could be the problem too.
Regards,
Ivan
>  -------Original Message-------
>  From: Paul Wheeler <pwheeler at digitalglobe.com>
>  To: gdal-dev at lists.osgeo.org
>  Subject: [gdal-dev] ogr_OCI plugin can't find OCI.dll
>  Sent: Aug 09 '12 08:58
>  How do I get the answer to this question, I am having the same problem
>  PAUL WHEELER
>  ETL Developer
>  OFFICE: 303.684.1321
>  MOBILE: 620.717.1015
>  [LINK: http://www.digitalglobe.com/] www.digitalglobe.com
>  This electronic communication and any attachments may contain confidential
>  and proprietary  information of DigitalGlobe, Inc. If you are not the
>  intended recipient, or an agent or employee  responsible for delivering
>  this communication to the intended recipient, or if you have received  this
>  communication in error, please do not print, copy, retransmit, disseminate
>  or  otherwise use the information. Please indicate to the sender that you
>  have received this  communication in error, and delete the copy you
>  received. DigitalGlobe reserves the  right to monitor any electronic
>  communication sent or received by its employees, agents  or
>  representatives.
>  _______________________________________________
>  gdal-dev mailing list
>  [LINK: compose.php?to=gdal-dev at lists.osgeo.org] gdal-dev at lists.osgeo.org
>  [LINK: http://lists.osgeo.org/mailman/listinfo/gdal-dev]
