[gdal-dev] What should I expect?
Martin Chapman chapmanm at pixia.com
Fri Aug 10 09:09:52 PDT 2012
Jorge,
It's a south up image.  If the gsd x value is negative the image is an
east to west image.  Normally a north up image will have a positive gsd x
and a negative gsd y.
Marty
-----Original Message-----
[mailto:gdal-dev-bounces at lists.osgeo.org] On Behalf Of Jorge Arevalo
Sent: Friday, August 10, 2012 9:39 AM
To: gdal-dev at lists.osgeo.org
Subject: [gdal-dev] What should I expect?
Hello,
If while I'm executing gdalinfo against a raster layer I get a positive
value for pixel size Y, what of these scenarios is possible?
- The raster's map coordinate system sets the origin of the data in the
upper left corner.
- The raster is not georeferenced and its coordinates are interpreted as
image pixels, instead of map units.
- Any other situation (corrupt file?, other?)
I know this value is almost always negative. For example, in case of UTM
coordinate system. But, how common is to have a positive value for Y
coordinate?
Many thanks in advance
Jorge Arevalo
http://www.libregis.org
gdal-dev mailing list
http://lists.osgeo.org/mailman/listinfo/gdal-dev
