[gdal-dev] Possible bug: hard limit to the number of Datasets creatable in a Python process?
Michal Migurski
mike at stamen.com
Tue Aug 14 13:00:32 PDT 2012
On Aug 14, 2012, at 12:37 PM, Even Rouault wrote:
> Le mardi 14 août 2012 21:00:20, Michal Migurski a écrit :
>> I'm experiencing a reproducible bug.
>> I create new 258x258 pixel datasets like this:
>> driver = gdal.GetDriverByName('GTiff')
>> handle, filename = mkstemp(dir=tmpdir,
>> prefix='dem-tools-hillup-data-render-', suffix='.tif') ds =
>> driver.Create(filename, width, height, 1, gdal.GDT_Float32)
>> I also open a number of datasets in the same process using gdal.Open() and
>> warp them together with gdal.ReprojectImage().
>> When I have created 1,020 new datasets / opened 2,041 total datasets, I get
>> a None back from driver.Create(). This number is stable, and appears
>> unrelated to the specific datasets that I'm creating. Datasets are being
>> flushed and falling out of scope, so I believe that they're correctly
>> being closed when they should. Do these numbers sound like known, hard
>> internal limits to anyone?
> I don't think it is a bug in GDAL, but an issue in your script. This sounds
> like you hit the default limit of 1024 files opened simultaneously by a Linux
> process. So I suspect that your datasets are not properly closed.
> Calling ds.FlushCache() is not sufficient. In principle, if the dataset handle
> goes out of scope, it should be destroyed, so I suspect that it is not the
> case. Assigning None to the dataset will force its closing.
Great, thank you Even.
I have a place to look now. When I watch the output of lsof as the script runs, I can see that the failure occurs near the moment where the number of open file handles approaches 1024.
I've added `ds = None` to the relevant parts of my script, but I don't think the file handles are actually being closed. Here's an excerpt of lsof output for the specific pid, which shows correctly that the TIF files have each been deleted but handles remain open:
python 4719 migurski 127u REG 8,1 267898 65148403 /tmp/dem-tools-hillup-data-render-KvUA8d.tif (deleted)
python 4719 migurski 128u REG 8,1 267898 65148404 /tmp/dem-tools-hillup-data-render-MAwCVw.tif (deleted)
python 4719 migurski 129u REG 8,1 267898 65148405 /tmp/dem-tools-hillup-data-render-M_NvT_.tif (deleted)
python 4719 migurski 130u REG 8,1 267898 65148406 /tmp/dem-tools-hillup-data-render-dV1p7h.tif (deleted)
python 4719 migurski 131u REG 8,1 267898 65148407 /tmp/dem-tools-hillup-data-render-rmuD4b.tif (deleted)
python 4719 migurski 132u REG 8,1 267898 65148408 /tmp/dem-tools-hillup-data-render-KGtcFD.tif (deleted)
python 4719 migurski 133u REG 8,1 267898 65148409 /tmp/dem-tools-hillup-data-render-EI4Jkz.tif (deleted)
python 4719 migurski 134u REG 8,1 267898 65148410 /tmp/dem-tools-hillup-data-render-MnHVKl.tif (deleted)
python 4719 migurski 135u REG 8,1 267898 65148411 /tmp/dem-tools-hillup-data-render-oGd6_b.tif (deleted)
python 4719 migurski 136u REG 8,1 267898 65148412 /tmp/dem-tools-hillup-data-render-8p0cew.tif (deleted)
python 4719 migurski 137u REG 8,1 267898 65148413 /tmp/dem-tools-hillup-data-render-CZTPWc.tif (deleted)
I'm going to try switching to vsimem, maybe that will help.
-mike.
michal migurski- mike at stamen.com
415.558.1610
