[gdal-dev] [Proposed new feature] A '"SQLite" SQL dialect for OGR
Smith, Michael ERDC-RDE-CRREL-NH
Michael.Smith at erdc.dren.mil
Sat Aug 18 10:28:09 PDT 2012
This is "wicked cool".
Mike
Michael Smith
US Army Corps
Remote Sensing GIS/Center
On 8/18/12 1:03 PM, "Even Rouault" <even.rouault at mines-paris.org> wrote:
>Hi folks,
>I've attached in
>http://trac.osgeo.org/gdal/attachment/ticket/4782/sqlite_dialect.patch a
>patch
>that adds a SQLite alternate SQL dialect that can be used with any OGR
>datasource (only available if GDAL/OGR is configured with SQLite support
>of
>course)
>To remind you the concept of SQL dialects, for non-RDBMS OGR drivers, OGR
>uses
>its own SQL engine, which is the called the OGRSQL dialect. Whereas for
>RDBMS
>OGR drivers, their own SQL engine will be used, unless otherwise
>specified.
>This patchs adds the capability to use a SQLite dialect (through the
>-dialect
>option of ogrinfo or ogr2ogr for example). When doing so, the SQLite SQL
>engine is used, and when Spatialite is available, all the Spatialite
>functions
>( see http://www.gaia-gis.it/gaia-sins/spatialite-sql-3.0.0.html ) can
>also be
>used.
>Technically, this works thanks to a temporary in-memory SQLite DB and a
>module
>(ogr/ogrsf_frmts/sqlite/ogrsqlitevirtualogr.cpp) that exposes OGR layers
>to
>SQLite through its Virtual Table mechanism (
>http://www.sqlite.org/vtab.html
>). When the datasource you operate on is opened in update mode and that
>the
>corresponding OGR driver supports
>CreateFeature()/SetFeature()/DeleteFeature()
>operations, SQL INSERT/UPDATE/DELETE operations will work too.
>What do you think about it ?
>A few non-exhaustive examples of things you can do :
># Initial CSV file :
>$ cat my.csv
>id,foo,bar,long,lat
>1,"foo","bar",2,49
>1,"foo","bar",3,50
>2,"foo2","bar2",-2,49
>2,"foo2","bar2",-3,51
># Creates a Geometry field from each (long,lat) tuple :
>$ ogrinfo my.csv -dialect sqlite -sql "SELECT *, MakePoint(CAST(long AS
>FLOAT), CAST(lat AS FLOAT)) as geometry FROM my" -q
>Layer name: SELECT
>OGRFeature(SELECT):0
> id (String) = 1
> foo (String) = foo
> bar (String) = bar
> long (String) = 2
> lat (String) = 49
> POINT (2 49)
>OGRFeature(SELECT):1
> id (String) = 1
> foo (String) = foo
> bar (String) = bar
> long (String) = 3
> lat (String) = 50
> POINT (3 50)
>OGRFeature(SELECT):2
> id (String) = 2
> foo (String) = foo2
> bar (String) = bar2
> long (String) = -2
> lat (String) = 49
> POINT (-2 49)
>OGRFeature(SELECT):3
> id (String) = 2
> foo (String) = foo2
> bar (String) = bar2
> long (String) = -3
> lat (String) = 51
> POINT (-3 51)
># Merge all the points that have the same id into a line :
>$ ogrinfo my.csv -dialect sqlite -sql "SELECT id, foo,bar,
>MakeLine(MakePoint(CAST(long AS FLOAT), CAST(lat AS FLOAT))) FROM my
>GROUP BY
>id" -q
>Layer name: SELECT
> id (String) = 1
> foo (String) = foo
> bar (String) = bar
> LINESTRING (2 49,3 50)
> id (String) = 2
> foo (String) = foo2
> bar (String) = bar2
> LINESTRING (-2 49,-3 51)
># Compute the geodesic length of each line :
>GeodesicLength(SetSRID(MakeLine(MakePoint(CAST(long AS FLOAT), CAST(lat
>AS
>FLOAT))),4326)) AS total_length FROM my GROUP BY id" -q
>Layer name: SELECT
> id (String) = 1
> total_length (Real) = 132725.477910869
> id (String) = 2
> total_length (Real) = 233720.037020965
># Appends a new entry in the CSV :
>$ ogrinfo my.csv -dialect sqlite -sql "insert into my
>(id,foo,bar,long,lat)
>values (3,'foo3','bar3',2.5,49.5)"
>$ cat my.csv
>id,foo,bar,long,lat
>1,"foo","bar",2,49
>1,"foo","bar",3,50
>3,foo3,bar3,2.5,49.5
># Reprojection from EPSG:32631 to EPSG:4326 :
>$ ogrinfo poly.shp -dialect sqlite -sql "SELECT
>ST_Transform(SetSRID(GEOMETRY,32631),4326) AS GEOMETRY, * FROM poly WHERE
>EAS_ID = 170"
>INFO: Open of `poly.shp'
> using driver `ESRI Shapefile' successful.
>Layer name: SELECT
>Geometry: Unknown (any)
>Feature Count: 1
>Extent: (2.750069, 43.034444) - (2.751428, 43.035184)
>Layer SRS WKT:
>GEOGCS["WGS 84",
> DATUM["WGS_1984",
> SPHEROID["WGS 84",6378137,298.257223563,
> AUTHORITY["EPSG","7030"]],
> AUTHORITY["EPSG","6326"]],
> PRIMEM["Greenwich",0,
> AUTHORITY["EPSG","8901"]],
> UNIT["degree",0.0174532925199433,
> AUTHORITY["EPSG","9122"]],
> AUTHORITY["EPSG","4326"]]
>Geometry Column = GEOMETRY
>AREA: Real (0.0)
>EAS_ID: Real (0.0)
>PRFEDEA: String (0.0)
> AREA (Real) = 5268.813
> EAS_ID (Real) = 170
> PRFEDEA (String) = 35043413
> POLYGON ((2.751427625469495 43.034734578878634,2.750298298604006
>43.034443959553869,2.75006933958772 43.03490271631064,2.75124435992688
>43.035184432169061,2.751427625469495 43.034734578878634))
>Note: a similar capability was already available in OGR 1.9 for
>Shapefiles,
>through the use of the VirtualShape module that is embedded in
>Spatialite. See
>the http://gdal.org/ogr/drv_sqlite.html page.
>Best regards,
>Even
>_______________________________________________
>gdal-dev mailing list
>gdal-dev at lists.osgeo.org
>http://lists.osgeo.org/mailman/listinfo/gdal-dev
