[gdal-dev] gdaltindex
Even Rouault
even.rouault at mines-paris.org
Tue Aug 21 14:24:56 PDT 2012
Le mardi 21 août 2012 23:09:19, Ian Walberg a écrit :
> Hello folks,
> Can gdaltindex create a sqlite db instead of a shapefile.
Not directly, but you can use ogr2ogr to convert it to a sqlite db
> This would be for use with mapserver and we are finding some references
> to non shapefiles but cannot get it to work.
I'm not sure that MapServer supports something else than shapefiles as valid
format for tile index. You should confirm with the MapServer team.
> Thanks
> Ian
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
