[gdal-dev] can't handle grib file
Margherita Di Leo
diregola at gmail.com
Wed Aug 22 23:53:31 PDT 2012
Hi all,
I have a problem handling some grib files, I get a warning message and I
can't understand how to deal with it..
running gdalinfo, it says:
Un-handled possible ensemble section center 78 subcenter 255
[... several times, cut]
Driver: GRIB/GRIdded Binary (.grb)
Files:
/home/leomarg/Desktop/Fire_event_test_case_Valencia/grib/dwd_grib1_ispra_gmi202_2012063000
Size is 201, 161
Coordinate System is:
GEOGCS["Coordinate System imported from GRIB file",
DATUM["unknown",
SPHEROID["Sphere",6367470,0]],
PRIMEM["Greenwich",0],
UNIT["degree",0.0174532925199433]]
Origin = (-10.000000000000000,74.960000000000008)
Pixel Size = (0.000000000000000,-0.000000000000000)
Corner Coordinates:
Upper Left ( -10.0000000, 74.9600000) ( 10d 0' 0.00"W, 74d57'36.00"N)
Lower Left ( -10.0000000, 74.9600000) ( 10d 0' 0.00"W, 74d57'36.00"N)
Upper Right ( -10.0000000, 74.9600000) ( 10d 0' 0.00"W, 74d57'36.00"N)
Lower Right ( -10.0000000, 74.9600000) ( 10d 0' 0.00"W, 74d57'36.00"N)
Center ( -10.0000000, 74.9600000) ( 10d 0' 0.00"W, 74d57'36.00"N)
Band 1 Block=201x1 Type=Float64, ColorInterp=Undefined
Description = 10[m] HTGL (Specified height level above ground)
Metadata:
GRIB_COMMENT=u-component (zonal) of wind [m/s]
GRIB_ELEMENT=U
GRIB_FORECAST_SECONDS=0 sec
GRIB_REF_TIME= 1341014400 sec UTC
GRIB_SHORT_NAME=10-HTGL
GRIB_UNIT=[m/s]
GRIB_VALID_TIME= 1341014400 sec UTC
Band 2 Block=201x1 Type=Float64, ColorInterp=Undefined
Metadata:
GRIB_COMMENT=v-component (merdional) of wind [m/s]
GRIB_ELEMENT=V
GRIB_UNIT=[m/s]
Furthermore, when I try with gdal_translate to convert one of the bands in
tif format, the size of the pixels created is 0x0.
Thanks in advance for any hint.
Dr. Margherita Di Leo
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20120823/d687c21b/attachment.html>
