[gdal-dev] Converting a .dat(X-Plane) file to a shapefile
Peter Mallen peter.mallen at airborne.aero
Thu Aug 23 12:15:50 PDT 2012
I tried removing the leading anti-slash as well as adding "c:" to the path and the same error message was received for both instances.
I was able to convert the other.dat files from the downloaded data to shapefiles but for some reason the apt.dat file is not working.
-----Original Message-----
From: Even Rouault [mailto:even.rouault at mines-paris.org]
Sent: Thursday, August 23, 2012 12:00 PM
To: gdal-dev at lists.osgeo.org
Cc: Peter Mallen; Kyle Shannon
Subject: Re: [gdal-dev] Converting a .dat(X-Plane) file to a shapefile
Le jeudi 23 août 2012 20:57:19, Peter Mallen a écrit :
> Hi Klye,
> The errors received are below:
> FAILURE:
> Unable to open datasource '\APTNav201107XP900\apt.dat' with the
> following drivers.
Ah, this is just that the input filename is likely incorrect. Perhaps try removing the leading anti-slash, or if the APTNav201107XP900 directory is just at the root of the C drive, use "c:\APTNav201107XP900\apt.dat" instead.
