[gdal-dev] About sqlite tileindex and Mapserver
Rahkonen Jukka
Jukka.Rahkonen at mmmtike.fi
Fri Aug 24 04:12:37 PDT 2012
There is a trick with using Spatialite tileindex with Mapserver. I have no idea anymore how I came to this solution but most probably I was reading something about it from the internet.
Try odd trick is that you cannot user Spatialite directly as tileindex but you must first create a LAYER from Spatialite and use that as tileindex. Let's take an example. In the following "z:\tindex\aerial_images.sqlite" is the Spatialite db and tile locations are in the table "aerial_images"
LAYER
NAME "sqlite_tileindex"
STATUS OFF
TYPE POLYGON
CONNECTIONTYPE OGR
CONNECTION "z:\tindex\aerial_images.sqlite"
DATA "aerial_images"
END
Now for the real aerial image layer the tileindex is read from the LAYER that was just created
LAYER
NAME "aerial_imagery"
STATUS ON
TILEINDEX "sqlite_tileindex"
-Jukka Rahkonen-
