[gdal-dev] SQL Server Driver
Duchesne, Jimmy
JDuchesne at korem.com
Fri Aug 24 15:03:40 PDT 2012
Hello,
I've been using SQL Server Driver for a few days now, and I noticed it was very slow, whatever the parameters, such as GT, I was using.
I need to insert millions of rows in a table.
To give you an idea, it takes around 1 minute to import 10k records with the driver
On the other hand, if I write my own routine which reads a MapInfo file and does batch insert into the database, I can insert over 125k records per minute.
I tried reading the same TAB file with ogr2ogr but writing to PostGis and noticed the speed was about the same than my routine, which is enough for my needs.
Would it be possible that the SQL Server Driver does not do bulk insert?
Thanks for the help.
Jimmy Duchesne
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20120824/7885ade4/attachment.html>
