[gdal-dev] SQL Server Driver
Duchesne, Jimmy
JDuchesne at korem.com
Mon Aug 27 05:52:21 PDT 2012
Thanks for the answers guys.
What you're saying concurs with what I was experiencing, and I believe, what I was seeing with the SQL Server Management profiler.
Also, I don't know if inserting with something else than WKT would actually improve the performance because my test, bulk inserts done with Java, were also inserting using WKT.
Finally, just to be sure, is there any issue with using this driver on a Linux OS?
Jimmy.
-----Original Message-----
From: fwarmerdam at gmail.com [mailto:fwarmerdam at gmail.com] On Behalf Of Frank Warmerdam
Sent: August-24-12 6:39 PM
To: Duchesne, Jimmy
Cc: gdal-dev at lists.osgeo.org; Szekeres Tamás
Subject: Re: [gdal-dev] SQL Server Driver
Jimmy,
>From an examination of MSSQLSpatialTableLayer::CreateFeature() it
appears a regular INSERT statement is done for each feature written to
the db rather than any sort of bulk mechanism. I could be missing
something of course. Hopefully Tamas will provide a more experienced
answer.
Best regards,
Frank
On Fri, Aug 24, 2012 at 3:03 PM, Duchesne, Jimmy <JDuchesne at korem.com> wrote:
> Hello,
> I've been using SQL Server Driver for a few days now, and I noticed it was
> very slow, whatever the parameters, such as GT, I was using.
> I need to insert millions of rows in a table.
> To give you an idea, it takes around 1 minute to import 10k records with the
> driver
> On the other hand, if I write my own routine which reads a MapInfo file and
> does batch insert into the database, I can insert over 125k records per
> minute.
> I tried reading the same TAB file with ogr2ogr but writing to PostGis and
> noticed the speed was about the same than my routine, which is enough for my
> needs.
> Would it be possible that the SQL Server Driver does not do bulk insert?
> Thanks for the help.
> Jimmy Duchesne
> gdal-dev mailing list
and watch the world go round - Rush | Geospatial Software Developer
