[gdal-dev] autoreconf fails
Oliver Burger
oliver.bgr at googlemail.com
Tue Aug 28 05:05:57 PDT 2012
Currently I can't build gdal any more.
A normal build told me:
libtool: Version mismatch error. This is libtool 2.4.2, but the
libtool: definition of this LT_INIT comes from libtool 2.4.
libtool: You should recreate aclocal.m4 with macros from libtool 2.4.2
libtool: and run autoconf again.
But doing so, I get the following error message:
+ aclocal
configure.in:424: warning: macro 'AM_ICONV' not found in library
+ autoreconf
configure.in:78: error: possibly undefined macro: AC_LD_SHARED
If this token and others are legitimate, please use m4_pattern_allow.
See the Autoconf documentation.
configure.in:106: error: possibly undefined macro: AC_HAVE_LONG_LONG
configure.in:107: error: possibly undefined macro: AC_UNIX_STDIO_64
configure.in:155: error: possibly undefined macro: AC_CHECK_FUNC_CUSTOM
configure.in:424: error: possibly undefined macro: AM_ICONV
autoreconf: /usr/bin/autoconf failed with exit status: 1
Any ideas how to fix this?
Oliver
Oliver Burger aka obgr_seneca
Mageia contributor
