[gdal-dev] How to write many raster layers into PDF?
Jukka Rahkonen
jukka.rahkonen at mmmtike.fi
Wed Aug 29 23:25:56 PDT 2012
Is there a way to write several raster images into geospatial PDF so that they
would appear as own selectable layers in the resulting PDF? With extra vector
layers it is possible be making a .vrt file combines the original layers into
one OGR_DATASOURCE. Does this work somehow also with raster sources and if it
does, could it be possible to see a simple example?
-Jukka Rahkonen-
