[gdal-dev] Compiling GDAL with HDF5 Support
Etienne Tourigny
etourigny.dev at gmail.com
Thu Aug 30 10:29:28 PDT 2012
are you using the gdalinfo that you installed? You can find this out with
which gdalinfo
to make sure that hdf5 support was builtin, try gdalinfo --formats
also when you did configure, did it give you any errors about hdf5?
and try gdalinfo --debug on <file.hdf>
Etienne
On Thu, Aug 30, 2012 at 12:10 PM, elliott <elliott at cpi.com> wrote:
> Hello,
> I have configured gdal 1.9.1 as follows:
> ./configure --with-python --with-hdf4=/home/hdf-4.2.6/hdf4
> --with-hdf5=/home/hdf5-1.8.9/hdf5
> It looks like everything builds successfully. However, when I try to use
> gdalinfo on a MODIS Land Cover HDF-EOS version 5 file, I get the following
> error:
>> gdalinfo MCD12Q1.A2009001.h28v05.005.2011059194456.hdf
> ERROR 4: 'MCD12Q1.A2009001.h28v05.005.2011059194456.hdf' not recognized as
> a supported file format.
> gdalinfo failed - unable to open
> 'MCD12Q1.A2009001.h28v05.005.2011059194456.hdf'.
> Any ideas on what I am doing wrong?
> Thanks
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
