[gdal-dev] TIFF overviews issue
Fabian Schindler fabian.schindler at eox.at
Mon Dec 3 01:23:37 PST 2012
Perfect, your workaround works for me.
As I'm mostly dealing with small fairly small images, the performance
decrease may not be a concern for me. I'll stick with this solution
until I can definitely say that the target system has libtiff 4.0.
Thanks Even!
On 12/01/2012 11:37 AM, Even Rouault wrote:
>> I can also reproduce with libtiff 3.9.2. libtiff 3.X suffers sometimes from
>> some problems when generating overviews in a interleaved way, as it is
>> done by BuildOverviews("NEAREST", [2,4,8,16]). Those problems have been
>> corrected in libtiff 4.0
>> A way to workaround this is to generate each overview level one after
>> another one, like this :
>> out_ds.BuildOverviews("NEAREST", [ 2 ])
>> out_ds.BuildOverviews("NEAREST", [ 4 ])
>> out_ds.BuildOverviews("NEAREST", [ 8 ])
>> out_ds.BuildOverviews("NEAREST", [ 16 ])
>> This will work on both libtiff 3.X and libtiff 4.0. Note that it might
>> perform a little less than generating all the levels in a single
>> instruction, since the source data must be read several times.
> In the libtiff 3.X case, I've just implemented in GDAL trunk the workaround in
> the GTiff driver
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
