[gdal-dev] WFS DefaultSRS OtherSRS
xavier lhomme
lhomme.xavier at gmail.com
Tue Dec 4 01:01:08 PST 2012
Hi
I added this option &SRSNAME=urn:ogc:def:crs:EPSG:6.9:4326 to the WFS
connexion string on my datasource and it works.
but I tried on another datasource and the connexion failed with this
option. (whereas it works if you do not put the option at the end of the
connexion string);
I checked the GetCapabilities and I found that the datasource has some
layers with null extent (case)::
- <wfs:FeatureType>
<wfs:Name>BigMap:AquedctP</wfs:Name>
<wfs:Title>AquedctP</wfs:Title>
<wfs:DefaultSRS>urn:ogc:def:crs:EPSG:6.9:4326</wfs:DefaultSRS>
- <wfs:OutputFormats>
<wfs:Format>text/xml;
subType=gml/3.1.1/profiles/gmlsf/1.0.0/0</wfs:Format>
</wfs:OutputFormats>
- <ows:WGS84BoundingBox>
<ows:LowerCorner>NaN NaN</ows:LowerCorner>
<ows:UpperCorner>NaN NaN</ows:UpperCorner>
</ows:WGS84BoundingBox>
</wfs:FeatureType>
2012/11/28 Even Rouault <even.rouault at mines-paris.org>
> > How the wfs driver handles the OtherSRS ?
> > Is he handles only the DefaultSRS ?
> It will select the DefaultSRS, unless you add as an option like
> &SRSNAME=urn:ogc:def:crs:EPSG:6.9:4326 to the WFS connexion string.
> > berst regards
> > xavier
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20121204/abb6b093/attachment.html>
