[gdal-dev] v1.9.2 throws ERROR 4 exception, v1.6.1 does not
Homme Zwaagstra
hrz at geodata.soton.ac.uk
Fri Dec 7 02:57:07 PST 2012
Running `strace` might yield a little more information:
strace gdalinfo /mnt/stemdata02/kfw4/modis_landcover/tiles/MCD12Q1.A2011001.h33v07.051.2012264183744.hdf
Homme
On Thu, Dec 06, 2012 at 06:59:05PM +0000, Kevin F Webb wrote:
> Any suggestions Even? Permissions aren't an issue, same user executed all commands, LD_LIBRARY_PATH is identical, ld.so.conf was updated before the 2 builds, and ldd shows that the link files are all locatable.
> ________________________________________
> From: Even Rouault [even.rouault at mines-paris.org]
> Sent: Thursday, December 06, 2012 1:53 PM
> To: Kevin F Webb
> Cc: gdal-dev at lists.osgeo.org
> Subject: Re: [gdal-dev] v1.9.2 throws ERROR 4 exception, v1.6.1 does not
> Le jeudi 06 décembre 2012 19:48:34, Kevin F Webb a écrit :
> > attached
> > Thanks Even!
> Your file works me for both GDAL trunk and GDAL 1.9.0, so I suspect there is
> something wrong in your setup, or something else ...
> gdal-dev mailing list
Homme Zwaagstra
GeoData Institute
University of Southampton
Tel: +44(0)2380 59 8709
