[gdal-dev] v1.9.2 throws ERROR 4 exception, v1.6.1 does not
    Kevin F Webb
    kfw4 at cornell.edu
    Fri Dec  7 07:41:00 PST 2012
Another excellent suggestion!
Merci Even.
________________________________________
From: Even Rouault [even.rouault at mines-paris.org]
Sent: Friday, December 07, 2012 9:55 AM
To: Kevin F Webb
Cc: Homme Zwaagstra; gdal-dev at lists.osgeo.org
Subject: Re: [gdal-dev] v1.9.2 throws ERROR 4 exception, v1.6.1 does not
Selon Kevin F Webb <kfw4 at cornell.edu>:
> Excellent suggestion Homme!
> I can clearly see where the successful version takes off and the "failure"
> occurs, but no clear indication, to me at least, what the cause of the
> "failure" is. The library set is more complex than I've shown here, but the
> key libs should be those I've listed. I will attempt to instrument the 1.9.2
> version to get further insight what is causing the problem.
If you compile a version with debug symbols, I'd suggest that you just set a
breakpoint in HDF4Dataset::Open and then step line by line to figure out what
happens.
