[gdal-dev] EPSG 8.0 Upgrade
Frank Warmerdam
warmerdam at pobox.com
Fri Dec 7 10:53:28 PST 2012
Jan,
I think the easiest place to see them highlighted is in the changeset
applied to the PROJ.4 epsg init file:
http://trac.osgeo.org/proj/changeset/2294
Best regards,
Frank
On Thu, Dec 6, 2012 at 2:13 AM, Jan Hartmann <j.l.h.hartmann at uva.nl> wrote:
> Hi Frank, where do I find which datums have new datum shift solutions?
> Jan
> On 12/06/2012 01:18 AM, Frank Warmerdam wrote:
> Folks,
> At the request of Howard Butler, I have upgraded PROJ.4, libgeotiff, and
> GDAL to use the EPSG 8.0 database in development "trunk".
> This was accomplished, as usual based on the process described here:
> http://svn.osgeo.org/metacrs/geotiff/trunk/libgeotiff/csv/README
> Amoung other things this will result in some datums having new preferred
> datum shift solutions. Upgrade with care.
> Best regards,
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
I set the clouds in motion - turn up | Frank Warmerdam,
and watch the world go round - Rush | Geospatial Software Developer
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20121207/1270baee/attachment.html>
