[gdal-dev] FIDN-issue
Nikhil Sai Parupalli
nikhil.parupalli at iictechnologies.com
Mon Dec 10 23:22:07 PST 2012
Hi ,
In my application I am fetching S57 data set where it is fetching FIDN with negative value which is wrong because FIDN should be in Range: 1 to 2 power 32-1
Is there any instance that any one got the same issue.
If the same data source is loaded in Caris Easy view it is showing some other legal value.
Please load the sample data with any application in open source it will show the same as mentioned above
Thanks and Regards
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20121211/6aef7b24/attachment.html>
