[gdal-dev] Overviews using GDAL
Dmitry Baryshnikov
polimax at mail.ru
Tue Dec 11 06:01:34 PST 2012
When you use RasterIO
(http://www.gdal.org/classGDALDataset.html#ae077c53268d2272eebed10b891a05743)
GDAL automatically switch to right overview based on input parameters. I
think ArcGIS do it the same way.
Regards,
Dmitry
11.12.2012 16:58, HariPrasad пишет:
> Iam beginner to GDAL.
> I have an Image which has internal overviews in it. I am able to display
> each overview separately, but i want to dynamically select the corresponding
> overview when that image is zoomed in/out. Which method i need to use in
> GDAL to achieve this functionality. And how does ArcEditor 10 understand
> which overview to display.
> View this message in context: http://osgeo-org.1560.n6.nabble.com/Overviews-using-GDAL-tp5022226.html
> Sent from the GDAL - Dev mailing list archive at Nabble.com.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
