[gdal-dev] gdalwarp performance with many GCPs
Even Rouault
even.rouault at mines-paris.org
Wed Dec 12 07:12:41 PST 2012
Selon Knut-Frode Dagestad <knutfrodesoppel at hotmail.com>:
> Hi list,
> When warping images with many GCPs, the -tps switch (Thin Plate Spline)
> is found to be necessary to get decent accuracy. This makes however
> warping very slow. The only method I found to increase speed is the -et
> switch, but at cost of spatial accuracy.
> Below some comments about the other tries which did not help:
> - compiling GDAL with armadillo support had no effect on speed.
> Btw, to compile with armadillo I had to manually insert -llapack in the
> following line in configure:
> if test -z "`${CXX} testarmadillo.cpp -o testarmadillo -larmadillo
> 2>&1`" ; then .....
> Perhaps ${LIBS} should be added permanently to this line in trunk?
Could you file a ticket about that ?
> - compiling GDAL with OpenCL had also no effect. At first surprising,
> but looking at the opencl warp kernel it seems that it only makes a
> difference for other resampling algorithms than nearest neighbour?
The OpenCL warper was designed to speed-up computational intensive algorithms,
such as lanczos resampling. For nearest resampling, most of the time is spent in
I/O, or reprojection.
> - Increasing memory with -wm had no effect
Yes, it depends on particular configuration of source and target datasets,
particularly if they're tiled or not. Tuning this might be non obvious.
> - Using several threads (-multi -wo NUM_THREADS=ALL_CPUS) actually
> increased computing time significantly (my proj version is 4.7.1).
As underlined in
http://osgeo-org.1560.n6.nabble.com/gdal-dev-NEW-Multi-threaded-warping-td4980252.html
, you need proj 4.8.0 for lock-less reprojection. Older versions have a global
mutex that will prevent efficient parallism.
