[gdal-dev] Configure GDAL 1.9.1 with GEOS 3.3.6
Ran, Limei
lran at email.unc.edu
Thu Dec 13 05:51:43 PST 2012
Hello,
I compiled GEOS 3.3.6 on our Linux server and I used the following configure for GDAL 1.9.1 with GEOS installed dir:
./configure --prefix=/nas01/depts/ie/cempd/SA/sa_06_2009/src/libs/gdal-1.9.1/local --with-static-proj4=/nas01/depts/ie/cempd/SA/sa_06_2009/src/libs/proj-4.8.0/local --with-geos=/nas01/depts/ie/cempd/SA/sa_06_2009/src/libs/geos-3.3.6/local --with-libtiff=internal --with-png=internal --with-jpeg=internal --with-libz=internal --enable-linux-lfs --enable-static --without-curl --without-expat --without-mysql --without-dwgdirect --without-odbc --without-python --without-oci --without-sqlite3 --without-oci-include --without-oci-lib --without-ld-shared
But, I got GEOS support no at the end.
SQLite support: no
SpatiaLite support: no
DWGdirect support no
INFORMIX DataBlade support:no
GEOS support: no
VFK support: yes
Poppler support: no
Podofo support: no
I have:
config.status:S["GEOS_CONFIG"]="no"
config.status:S["GEOS_VERSION"]=""
config.status:S["HAVE_GEOS"]=""
config.status:S["GEOS_CFLAGS"]=""
config.status:S["GEOS_LIBS"]="/nas01/depts/ie/cempd/SA/sa_06_2009/src/libs/geos-3.3.6/local/lib"
I did uncomment the following:
nmake.opt:# Uncomment for GEOS support
nmake.opt:GEOS_DIR=/nas01/depts/ie/cempd/SA/sa_06_2009/src/libs/geos-3.3.6
nmake.opt:GEOS_CFLAGS = -I$(GEOS_DIR)/capi -I$(GEOS_DIR)/source/headers -DHAVE_GEOS
nmake.opt:GEOS_LIB = $(GEOS_DIR)/local/lib/geos_c_i.lib
Could you tell me where the problem could be?
Thanks,
Limei
