[gdal-dev] FileGDB -preserve_fid
Jeremy Palmer
JPalmer at linz.govt.nz
Thu Dec 13 15:36:31 PST 2012
Great thanks.
-----Original Message-----
From: gdal-dev-bounces at lists.osgeo.org [mailto:gdal-dev-bounces at lists.osgeo.org] On Behalf Of rburhum
Sent: Friday, 14 December 2012 8:41 a.m.
To: gdal-dev at lists.osgeo.org
Subject: Re: [gdal-dev] FileGDB -preserve_fid
Although FileGDB does have programmatic ways to preserve the FID, these are not exposed through the FileGDB API yet. What people normally do in these cases is to copy the fid to the target dataset as a non-primary key value. I guess we could add something along these lines as an enhancement request to the FileGDB driver.
View this message in context: http://osgeo-org.1560.n6.nabble.com/gdal-dev-FileGDB-preserve-fid-tp5022615p5022833.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
gdal-dev mailing list
http://lists.osgeo.org/mailman/listinfo/gdal-dev
This message contains information, which is confidential and may be subject to legal privilege. If you are not the intended recipient, you must not peruse, use, disseminate, distribute or copy this message. If you have received this message in error, please notify us immediately (Phone 0800 665 463 or info at linz.govt.nz) and destroy the original message. LINZ accepts no responsibility for changes to this email, or for any attachments, after its transmission from LINZ. Thank You.
