[gdal-dev] Can GDAL be configured to do direct I/O? (bypass cache, control blocksize, etc)
Ivan Lucena
ivan.lucena at princeton-ma.us
Fri Dec 14 06:30:50 PST 2012
Interesting: http://www.centos.org/docs/4/html/rh-gfs-en-6.1/s1-manage-direct-io.html
> -------Original Message-------
> From: Ethan Alpert <ealpert at digitalglobe.com>
> To: gdal-dev at lists.osgeo.org
> Subject: [gdal-dev] Can GDAL be configured to do direct I/O? (bypass cache, control blocksize, etc)
> Sent: Dec 14 '12 09:14
> Im running in to a situation where I believe the filesystem cache
> settings are screwing things up. Based on iozone tests Im not
> getting near the throughput I should for large 4gb+ files with multiple
> writing processes. It is a complex interaction of the number of dirty pages
> in filesystem cache in combination with small blocksize of the filesystem.
> Im still trying to figure this out but I can now get these machines
> to tip over with just iozone.
> Im actively working on how to refactor this code base to use GDAL
> WriteBlock but in absence of a solution there Im wondering if
> theres anyway to get GDAL writing using O_DIRECT?
> Thanks,
> -ethan
> This electronic communication and any attachments may contain confidential
> and proprietary information of DigitalGlobe, Inc. If you are not the
> intended recipient, or an agent or employee responsible for delivering
> this communication to the intended recipient, or if you have received this
> communication in error, please do not print, copy, retransmit, disseminate
> or otherwise use the information. Please indicate to the sender that you
> have received this communication in error, and delete the copy you
> received. DigitalGlobe reserves the right to monitor any electronic
> communication sent or received by its employees, agents or
> representatives.
> gdal-dev mailing list
> [LINK: compose.php?to=gdal-dev at lists.osgeo.org] gdal-dev at lists.osgeo.org
> [LINK: http://lists.osgeo.org/mailman/listinfo/gdal-dev]
