[gdal-dev] how to gdalwarp 4-band orthoimagery
Even Rouault even.rouault at mines-paris.org
Fri Dec 14 13:41:29 PST 2012
> And secondly the other method (using VRTs) how would one then automate that
> (to do, say 1000 tiles in a script).  The editing of the VRT would be the
> tricky part.
sed "s/<ColorInterp>Alpha<\/ColorInterp>//" should do it
But actually I think that if you just want to mosaic files in the same
projection you could also use gdalbuildvrt
